[GRASS-dev] table only creation in v.in.ascii
Hamish hamish_b at yahoo.com
Fri Jan 11 16:09:13 EST 2008
Benjamin Ducke wrote:
> However, I'd like to add the ability to read field names
> from the ascii input file to v.in.ascii.
that would be nice.
> Should I add a flag to interpret the first line as
> field labels?
It appears the scanning step may be interesting as a separate little
program, or a scan and exit. ie to prepare a columns= SQL line for you,
which you can check before using.
see also v.voronoi and v.delunay source code sharing, although I'm not
sure if that is the best implementation to mimic for a db.in.ascii.
> Does anyone know what the restrictions on DBF field
> names are? Length? Special characters?
10 chars long, case insensitive, spaces to underscores.
Special chars may be ok but I don't remember ever seeing any, and
considering dBase's age I'd stick to [a-z][0-9] ASCII chars.
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
