[GRASS-dev] wxgrass error in latest svn
Hamish hamish_b at yahoo.com
Fri Jan 11 16:33:01 EST 2008
> Carlos:
> > I just compiled grass 6.3 from SVN. Everything seems to be OK, but
> > if I try to run wxgrass:
> > GRASS 6.3.svn (amsul_wgs84):~ > wxgrass
> > GRASS 6.3.svn (amsul_wgs84):~ > Traceback (most recent call last):
> >   File "/usr/local/grass-6.3.svn/etc/wx/wxgui.py", line 42, in
> <module>
> >     import wx.aui
> > ImportError: No module named aui
Martin:
> take a look at gui/wxpython/README
> wxPython >= 2.8.1.1
> is required
as this is a common problem (with little hope in sight for Debian users
I am afraid) could a wx version-check be added to the start of the
python GUI startup code? Then at least there would be a more
understandable error message.
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
