[GRASS-dev] G_message () family of functions
Ivan Shmakov ivan at theory.asu.ru
Sat Jan 12 12:20:24 EST 2008
>>>>> Ivan Shmakov <ivan at theory.asu.ru> writes:
 > BTW, the correct pattern for issuing a string message is:
 > G_message ("%s", string);
 > not:
 > G_message (string);
	May I suggest the following patch?
--- lib/gis/error.c	2008-01-03 14:15:58.000000000 +0600
+++ lib/gis/error.c	2008-01-12 23:14:50.000000000 +0600
@@ -93,6 +93,16 @@
                         time_t, const char *);
 static int log_error (const char *, int);
+static int
+vfprint_error (int type, const char *template, va_list ap)
+    char buffer[2000];  /* G_asprintf does not work */
+    vsprintf (buffer, template, ap);
+    return print_error (buffer, type);
  * \fn void G_message (const char *msg,...)
@@ -105,15 +115,11 @@
-    char buffer[2000];  /* G_asprintf does not work */
-    va_list ap;
     if( G_verbose() >= G_verbose_std() ) {
+	va_list ap;
 	va_start(ap, msg);
-	vsprintf(buffer,msg,ap);
+	vfprint_error (MSG, msg, ap);
 	va_end(ap);
-	print_error (buffer,MSG);
@@ -130,15 +136,11 @@
 void G_verbose_message (const char *msg, ...)
-    va_list ap;
     if( G_verbose() > G_verbose_std() ) {
+	va_list ap;
 	va_start(ap, msg);
 	va_end(ap);
-	G_message(buffer);
@@ -158,15 +160,11 @@
 void G_important_message(const char *msg, ...)
-    va_list ap;
     if( G_verbose() > G_verbose_min() ) {
+	va_list ap;
 	va_start(ap, msg);
 	va_end(ap);
@@ -194,14 +192,11 @@
 int G_fatal_error (const char *msg,...)
-    char buffer[2000];  /* No novels to the error logs, OK? */
     va_list ap;
     va_start(ap,msg);
+    vfprint_error (ERR, msg, ap);
     va_end(ap);
-    print_error (buffer,ERR);
     exit (EXIT_FAILURE);
@@ -221,15 +216,13 @@
 int G_warning (const char *msg, ...)
     va_list ap;
     if (no_warn) return 0;
     va_start(ap,msg);
+    vfprint_error (WARN, msg, ap);
     va_end(ap);
-    print_error (buffer,WARN);
     return 0;
