[GRASS-dev] sqlite and grass64
Sun Jan 13 18:40:54 EST 2008
Michael Barton wrote:
> >> I would like to ask you for your opinion... to use sqlite as default
> >> db driver for grass64 (instead of dbf). What do you think?
> > Yes, that would be very good. AFAIK:
> > Functionality
> > - it does all the DBF driver does and way more
> > Portability
> > - works on all common operating systems
> > Installation efforts:
> > - despite the base installation, zero maintenance
> > Markus
> AFAICT, SQLite has considerably more functionality than our current
> dbf driver. I like it for a lot of reasons. A couple issues to
> consider, however.
> dbf is a widely recognized file format that can be read or imported by
> very many other applications directly. While the SQLite database
> engine can export into several interchange format, the native SQLite
> file format is much less widely read by other applications.
I would have expected most applications to access databases via ODBC,
rather than trying to interface with DBMS-specific libraries,
protocols or file formats directly.
