[GRASS-dev] Re: [GRASS-trac] #18: Grass63 -wx gui function r.in.xyz form not updating input fields.
GRASS-trac trac at osgeo.org
Sun Jan 13 17:42:22 EST 2008
  Reporter:  brian   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  major   |   Milestone:  6.4.0
 Component:  Python  |     Version:  svn-trunk
Resolution:          |    Keywords:  r.in.xyz wxgrass
Changes (by martinl):
  * component:  default => Python
Comment:
 Replying to [comment:2 brian]:
 > Am using compiled svn-trunk.
 > Setup two systems at work with grass_trunk at identical builds (29702),
 one a Ubuntu 7.10 and the other Mandriva 2008.
 > I can repeat the fault on the Ubuntu system, however the Mandriva system
 performs the test ok.
 > The configure options are different between systems, see attached files.
 Hm, strange, are you using the same version of wxPython on Ubuntu and
 Mandriva?
 $ python
 import wx
 wx.__version__
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/18#comment:3>
GRASS-trac <http://grass.osgeo.org>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
