[GRASS-dev] Python GUI requirements
Sun Jan 13 19:18:41 EST 2008
Maris Nartiss wrote:
> current trunk ./configure --help says that --with-python will enable
> Python support (Python bindings?).
Yes.
> Still I don't see any switch to enable/disable wxpython. Shouldn't
> there be one?
It isn't needed. The Tcl/Tk and Python checks in gui/Makefile are both
bogus; those directories should be processed regardless of whether or
not Tcl/Tk or Python are installed on the build system.
The Tcl/Tk check is meant for code which links against the Tcl/Tk
libraries, namely NVIZ, v.digit and the form library.
