[GRASS-dev] what if: Anything series?
Ivan Shmakov ivan at theory.asu.ru
Mon Jan 14 04:57:27 EST 2008
>>>>> Markus Neteler <neteler at osgeo.org> writes:
 >> Take a look at the minor change for lib/insert_raster.sh as well
 >> (attached.)
 > Looks much more polished. But it looks like bash to me, right?  So
 > far we try to avoid bash-isms in GRASS for portability.  Or will it
 > run with ash, too?
	It seems that both `local' and `$(COMMAND)' are available in
	either `dash' or BusyBox' `ash', e. g.:
$ cat test.sh
a=
f () { local a="$1" ; echo "$a" ; }
f "$(echo Hello, world\!)"
echo "\"$a\" is expected to be an empty string"
$ dash test.sh
Hello, world!
"" is expected to be an empty string
$ ash test.sh
Hello, world!
	It's probably reasonable to require a Shell implementation with
	either once you're depending on Shell functions being available.
	I'm not sure that these constructs are mandated by any standard,
	though.
	The `test' (`[ ... ]') command should be generally available as
	well.  IIRC, it's mandated by POSIX.
 >> In particular, I believe that the generic arrays storage facility is
 >> needed in GRASS for a long time.  At the very least, the ability to
 >> access arbitrary arrays in `r.mapcalc' expressions sounds quite
 >> appealing to me.
 >> Implementing this facility would effectively split the raster data
 >> set implementation into the generic ``raster'' (or ``array'') part
 >> and the specific ``geospatial'', ``color mapping'', and ``who knows
 >> what'' ones.
 > I do agree that the raster part needs a radical renovation. Some team
 > members also have ideas here - hope it comes true for GRASS 7.
	Are these collected anywhere on the Web (besides of [1, 2])?
[1] http://grass.gdf-hannover.de/wiki/GRASS_7_ideas_collection
[2] http://grass.gdf-hannover.de/wiki/Replacement_raster_format
