[GRASS-dev] Re: [GRASS-user] Unable to create new project with Grass
Michael Barton michael.barton at asu.edu
Mon Jan 14 11:50:21 EST 2008
This suggests a problem with g.proj, since both EPSG and georeferenced
file methods use it for creating a location, but specifying parameters
does not. This is beyond my area of expertise, but maybe someone else
on the dev list can troubleshoot now.
Michael
______________________________
Michael Barton, Professor
Professor of Anthropology
Director of Graduate Studies
School of Human Diversity & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Jan 14, 2008, at 9:20 AM, Jan Schorn wrote:
> Hi Michael,
> creating Locations specifying projection parameters works fine.
> Creating Locations from georeferenced file ( http://atlastenerife.es/TeIDE2/Descarga_Publica.do?fichero=830
>  ) causes an 'Error de la aplicación' ;-). Both versions, the 6.2.2
> (64 bit) and 6.2.3 (32 bit) one, are displaying the same error log
> (see below).
> The file used doesn't make problems importing it into a location.
> Good luck :-)
> Jan
> Error: /usr/bin/x-terminal-emulator: ...
> *Details:*
> /usr/bin/x-terminal-emulator: to set an icon, please use -name
> <profile> and set a profile icon
>   while executing
> "exec -- $env(GISBASE)/etc/grass-xterm-wrapper -T g.proj -n g.proj -
> e $env(GISBASE)/etc/grass-run.sh g.proj -c georef=$filepath location=
> $fileLocation"
>   invoked from within
> ".fileloc.def invoke"
>   ("uplevel" body line 1)
>   invoked from within
> "uplevel #0 [list $w invoke]"
>   (procedure "tk::ButtonUp" line 22)
>   invoked from within
> "tk::ButtonUp .fileloc.def"
>   (command bound to event)
> Michael Barton escribió:
>> Jan,
>> Is EPSG location creation the only thing that fails? Can you create
>> locations from georeferenced files and by specifying projection
>> parameters?
>> I just tried creating a location from EPSG code 4326 and it worked
>> fine in GRASS 6.3 compiled a few days ago. I don't know if this is
>> a problem related to 6.2 or not
>> Glynn Clements discussed a problem with shared libraries in Linux
>> that might or might not be a help. I am copying it below.
>> Michael
>> C. Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> www: <www.public.asu.edu/~cmbarton>
>> ======== shared library post ==============
>> Date: Sun, 13 Jan 2008 23:34:52 +0000
>> From: Glynn Clements <glynn at gclements.plus.com>
>> Subject: Re: [GRASS-user] Error creating new mapset
>> To: "Jose A. Ruiz-Arias" <jararias at ujaen.es>
>> Cc: grass-user at lists.osgeo.org
>> Message-ID: <18314.40988.419833.583423 at cerise.gclements.plus.com>
>> Content-Type: text/plain; charset=us-ascii
>> Jose A. Ruiz-Arias wrote:
>>> i have installed GRASS-6.2.3 from source code with no apparent
>>> errors during
>>> configuration, compilation and installation. However, when i run
>>> grass and
>>> try to create a new mapset i get next error:
>>> g.region: error while loading shared libraries: libgdal.so.1:
>>> cannot open
>>> shared object file: Error 40
>>> In fact, when i was setting the projection parameters and chose a
>>> UTM
>>> projection, the program did not ask me for the UTM zone, the
>>> ellipsoid and
>>> the datum.
>>> In the GRASS configure process I explicitely used the
>>> flag --with-gdal=/usr/local/bin/gdal-config and there were no
>>> errors. I
>>> checked for the shared library and it is placed in /usr/local/lib
>>> directory.
>>> Before the GRASS installation, I installed the GDAL/OGR bundle
>>> from the source
>>> code, with netcdf support, and the GRASS support disabled. Again,
>>> there were
>>> no apparent errors. Next I installed the gdal-grass plugin (gdal-
>>> grass-1.4.3
>>> with the following options:
>>> configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/usr/
>>> local/grass-6.2.3)
>>> I did not detect any problem during the installation of these
>>> bundles. Anyone
>>> knows about the problem??
>> Most systems won't load shared libraries from /usr/local/lib without
>> some additional configuration.
>> For Linux, you need to either set the LD_LIBRARY_PATH environment
>> variable to a path which includes /usr/local/lib, or add
>> /usr/local/lib to /etc/ld.so.conf then run ldconfig (as root).
