[GRASS-dev] Python GUI requirements
Mon Jan 14 15:34:40 EST 2008
Paul Kelly wrote:
> >>> current trunk ./configure --help says that --with-python will enable
> >>> Python support (Python bindings?).
> >> Yes.
> >>> Still I don't see any switch to enable/disable wxpython. Shouldn't
> >>> there be one?
> >> It isn't needed. The Tcl/Tk and Python checks in gui/Makefile are both
> >> bogus; those directories should be processed regardless of whether or
> >> not Tcl/Tk or Python are installed on the build system.
> > now gui/Makefile checks for wxPython instead of Python. wxPython stuff
> > is installed only if --with-wxpython is given.
> I think Glynn's point was that the installation should simply  be
> unconditional with no checks in gui/Makefile - the wxPython stuff is just
> scripts and doesn't need Python to be installed on the compilation system
> for the scripts to be processed in any way (unlike C compiling) - the
> requirement for wxPython is only on the system that GRASS is run on so it
> should be a runtime check rather than a comile-time check.
Exactly.
If you're cross-compiling e.g. building a Windows version on a Linux
system, you shouldn't need to have a Windows version of
Python/wxPython installed on the build system.
Configure checks identify the compilation environment, not the
run-time environment.
