[GRASS-dev] what if: Anything series?
Ivan Shmakov oneingray at gmail.com
Tue Jan 15 00:12:16 EST 2008
>>>>> Markus Neteler <neteler at osgeo.org> writes:
 >> It's probably reasonable to require a Shell implementation with
 >> either once you're depending on Shell functions being available.
 >> I'm not sure that these constructs are mandated by any standard,
 >> though.
 >> The `test' (`[ ... ]') command should be generally available as
 >> well.  IIRC, it's mandated by POSIX.
 > I would leave this to others - I am not much expert of POSIX.
	On the other hand, the change to use just one `sed' invocation
	is probably worth applying anyway.
 >>> I do agree that the raster part needs a radical renovation. Some
 >>> team members also have ideas here - hope it comes true for GRASS
 >>> 7.
 >> Are these collected anywhere on the Web (besides of [1, 2])?
 >> [1] http://grass.gdf-hannover.de/wiki/GRASS_7_ideas_collection
 >> [2] http://grass.gdf-hannover.de/wiki/Replacement_raster_format
 > AFAIK some material was collected in the Wiki from mailing list
 > discussions: http://lists.osgeo.org/pipermail/grass-dev/
 > More is scattered around in the list archive.  (use e.g.
 > http://www.nabble.com/forum/Search.jtp?query=raster+format&sort=date&local=y&forum=1200
 > to find more).
	ACK.  Thanks.
