[GRASS-dev] Re: grass-dev Digest, Vol 21, Issue 30
Wed Jan 16 17:44:57 EST 2008
Martin Landa wrote:
> > > It also should build library for wx digitization tool in the future,
> > > etc.
> > This would probably require the Python checks, as it would need to
> > build Python wrappers for GRASS functions, but it still shouldn't need
> > the wxPython checks.
> Well I am not sure about wx/wxpython version check. C/C++ code needed
> for digitization tool is compiled against wx library. So maybe
> checking wx version makes sense.
In that case, yes. I had assumed that the GUI was written in Python
with the C/C++ code only calling GRASS. If the C/C++ code is also
calling wx, then it needs to use the configure checks.
