[GRASS-dev] Re: d.thematic.area
Fri Jan 18 19:13:13 EST 2008
Hamish wrote:
> see previous discussions about default render mode for d.vect.
> this reminds me that we still need  an answer for that question before
> releasing 6.3.0.
Realistically, I think that it needs to be "c". "g" doesn't work with
vector-based drivers. The others all risk exceeding the 16-bit range
of XDRIVER, and modifying XDRIVER to perform its own clipping is too
radical a change at this stage.
That still leaves the problem with clipping polylines (segments
introduced by clipping are stroked), which I'll look into.
