[GRASS-dev] [GRASS-trac] #20: Vector point shift in wxgrass after pan
GRASS-trac trac at osgeo.org
Sat Jan 19 09:00:40 EST 2008
 Reporter:  marisn   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  6.3.0
Component:  default  |     Version:  svn-trunk
 Keywords:           |
 After panning around in wxgrass map window, some points are drawn shifted
 away from their location.
 Steps to reproduce:[[BR]]
 1) Add some line layer in wxgrass (i.e. roads from spearfish6);[[BR]]
 2) Add some point layer (i.e. bugsites);[[BR]]
 3) Take a screenshot;[[BR]]
 4) Pan map;[[BR]]
 5) Take a screenshot;[[BR]]
 6) In Gimp (or any other raster manipulation soft) combine both
 screenshots in such way, that line layer features match;[[BR]]
 7) Examine all point features and notice unsharp points - those are not
 drawn in same place as in first screenshot.[[BR]]
 User may expect, that all points are drawn with same distances between
 them during pan.
 GRASS svn trunk Revision: 29746[[BR]]
 32bit Gentoo with wxpython-2.8.7.1
Ticket URL: <http://trac.osgeo.org/grass/ticket/20>
GRASS-trac <http://grass.osgeo.org>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
