[GRASS-dev] Re: [GRASS-trac] #7: Location wizard: should predefine DB connection for new location
Moritz Lennert mlennert at club.worldonline.be
Mon Jan 21 04:16:25 EST 2008
>   Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
>       Type:  defect   |      Status:  new
>   Priority:  major    |   Milestone:  6.3.0
>  Component:  default  |     Version:  svn-trunk
> Resolution:           |    Keywords:
> Comment (by hamish):
>  For fixing C modules it should be as hard as testing a return value and
>  calling G_fatal_error() with "DB unset. Please run db.select".
>  For scripts it should be as simple as either calling db.select in the
>  script if unset or just letting the C module's G_fatal_error() spit out
>  the appropriate error.
I imagine you mean db.connect instead of db.select...
Moritz
