[GRASS-dev] Re: [GRASS GIS] #22: Grass r.out.mat 64bit Matlab reading problem
GRASS GIS trac at osgeo.org
Thu Jan 24 05:21:08 EST 2008
  Reporter:  alexice  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  minor    |   Milestone:  6.3.0
 Component:  default  |     Version:  6.2.3
Resolution:           |    Keywords:
Comment (by hamish):
 Glynn wrote on grass-dev ml:
 > Actually, I would suggest using big-endian format. That way, if
 > someone writes code which ignores byte order (i.e. just read
 > directly into memory), you discover it sooner rather than later.
 > [On a related issue, the UK is at a disadvantage when it comes to
 > writing code which deals with timezones. If you confuse GMT and
 > local time, you won't notice until daylight-saving time starts.]
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:7>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
