[GRASS-dev] svn seems to complete commit to repository, but hang locally
Patton, Eric epatton at nrcan.gc.ca
Fri Jan 25 15:09:09 EST 2008
On Jan 25, 2008 6:35 PM, Patton, Eric <epatton at nrcan.gc.ca> wrote:
>> I'm having trouble with svn today...for some reason, the svn commit hangs at "Transmitting file data ." even though the commit seems to have been completed and is browse-able on the repository. >>Has anyone had trouble uploading commits? Server problem, maybe?
>Eric,
>I was told that this happens when the CIA IRC bot hangs
>(http://cia.vc/stats/project/GRASS).
>The SVN server should be ok. If you can access IRC, you could in those moments
>irc://irc.freenode.net/osgeo
>or
>irc://irc.freenode.net/telascience (preferred). Then the OSGeo
>sysadmins could check.
>Markus
Thanks for the hints; I'll give it a try next time.
~ Eric.
