[GRASS-dev] G_message () family of functions
Ivan Shmakov ivan at theory.asu.ru
Sat Jan 26 13:12:21 EST 2008
>>>>> Markus Neteler <neteler at osgeo.org> writes:
 > Ivan, before your libgis patch gets lost: should it be applied?
	I believe it should.
 > According to Glynn it looked reasonable AFAIK.
 > Please send it to me (maybe offlist) for inclusion.
	Surely.
	BTW, since you apparently are using Google mail, you can try to
	use `Download' on the ``Show original'' link for a message to
	get it unaltered.
 >>> +    char buffer[2000];  /* G_asprintf does not work */
 >>> +    vsprintf (buffer, template, ap);
 >> It would be nice to use vsnprintf(), but we would need to check that
 >> it's available (it's not in C89).
	It would be even better to check for vasprintf () and use it if
	it's available.  Like:
static int
vfprint_error (int type, const char *template, va_list ap)
    int result;
#ifdef HAVE_VASPRINTF
    char *buffer;
    vasprintf (&buffer, template, ap);
    if (buffer == 0) {
        return -1;
    result = print_error (buffer, type);
    free (buffer);
#else
#ifdef HAVE_VSNPRINTF
    vnsprintf (buffer, sizeof (buffer), template, ap);
#else
#endif
#endif
    return result
	However, I see no reason for why gnulib/lib/vasnprintf.c cannot
	be used for a portable implementation of vasprintf ().  Reusing
	it would also obviate the need in lib/gis/asprintf.c.  And,
	well, doesn't eliminating extra code ease maintenance?
