[GRASS-dev] suggestion for g.region -a
Mon Jan 28 01:08:58 EST 2008
Michael Barton wrote:
> Currently, if you use the -a flag with g.region it will align the
> region exactly to match the resolution of a map (e.g. g.region -a
> rast=myrast will set the region to exactly the resolution of myrast
> regardless of the extents) or the resolution specified in the res or
> ewres/nwres fields (e.g. g.region -a n=523 s=15 res=10 will adjust
> the extents a little to make sure the resolution is exactly 10).
> However, -a is ignored if the map argument (rast=) or resolution
> arguments are blank.
Actually, you need either vect= or res= (or nsres= or ewres=). rast=
doesn't have any effect. Also, the interpretation is different for
vect= compared to the resolution options.
> This means that if you want to change the
> extents and keep your current resolution, you need to specify the -a
> flag AND explicitly specify the resolution. Otherwise, the resolution
> will be adjusted slightly.
> Could this be modified so that when the -a flag is used and
> resolution is NOT specified and a map is NOT specified (i.e., only
> changing extents) it aligns to the current resolution? That is,
> respect the -a flag when res/ewres/nsres= is blank and rast= is blank.
It would be possible to implement the -a flag unconditionally,
although you would need to exclude the cases which already have a
defined meaning (e.g. "g.region -a nsres=..." only aligns the top and
bottom edges, leaving the left and right edges unchanged).
