[GRASS-dev] Patch for 3D hull generation
Markus Neteler neteler at osgeo.org
Mon Jan 28 09:07:26 EST 2008
Hi Benjamin,
tested and uploaded. I have added an example but your is
much nicer. Please consider to patch description.html for
this (then we could upload also your nice screenshot).
concerning the chull.c copyright - to me it looks GPL compliant:
This code is described in "Computational Geometry in C" (Second Edition),
Chapter 4.  It is not written to be comprehensible without the
explanation in that book.
Input: 3n integer coordinates for the points.
Output: the 3D convex hull, in postscript with embedded comments
        showing the vertices and faces.
Compile: gcc -o chull chull.c
Written by Joseph O'Rourke, with contributions by
  Kristy Anderson, John Kutcher, Catherine Schevon, Susan Weller.
Last modified: March 1998
Questions to orourke at cs.smith.edu.
This code is Copyright 1998 by Joseph O'Rourke.  It may be freely
redistributed in its entirety provided that this copyright notice is
not removed.
So I have uploaded it to SVN.
Markus
On Jan 18, 2008 10:10 AM, Benjamin Ducke <benjamin.ducke at ufg.uni-kiel.de> wrote:
> Dear all,
> I have attached a patch that extends v.hull to accept 3D vector point
> maps and create a 3D hull composed of faces and a kernel at the 3D
> geometric center of the hull.
> I have attached a small screenshot from ParaView to show what I mean.
> The patch is against SVN trunk. Apply inside v.hull subdir with -p1.
> Cheers,
> Benjamin
> Benjamin Ducke, M.A.
> Archäoinformatik
> (Archaeoinformation Science)
> Institut für Ur- und Frühgeschichte
> (Inst. of Prehistoric and Historic Archaeology)
> Christian-Albrechts-Universität zu Kiel
> Johanna-Mestorf-Straße 2-6
> D 24098 Kiel
> Germany
> Tel.: ++49 (0)431 880-3378 / -3379
> Fax : ++49 (0)431 880-7300
> www.uni-kiel.de/ufg
