[GRASS-dev] Re: missing win32file module for wingrass wxgrass?
Markus Neteler neteler at osgeo.org
Tue Jan 29 02:46:19 EST 2008
On Jan 28, 2008 11:43 PM, Gerald Nelson <gnelson at uiuc.edu> wrote:
> Here's the process I went through
> - downloaded the wx gui code from trunk
> - placed it in the etc directory (not the gui directory)
> - moved the script to the right place
> - added python25 to the msys path. It's not there by default
> - started grass63 from inside msys
> - the tcltk gui starts
> - from msys command line type wxgrass
> - get the following error
> Traceback (most recent call last):
>   File "c:/grass63RC4/grass-6.3.0RC4/etc/wx/wxgui.py", line 53, in <module>
>     import gui_modules.utils as utils
>   File "c:\grass63RC4\grass-6.3.0RC4\etc\wx\gui_modules\utils.py", line 23,
> in <module>
>     import gcmd
>   File "c:\grass63RC4\grass-6.3.0RC4\etc\wx\gui_modules\gcmd.py", line 35,
> in <module>
>     from win32file import ReadFile, WriteFile
> ImportError: No module named win32file
> Where should this be?
Could it be that you need to install this:
http://sourceforge.net/projects/pywin32/
Markus
