[GRASS-dev] v.univar question: Why not lines and areas?
Moritz Lennert
mlennert at club.worldonline.be
Wed Jan 30 01:38:52 EST 2008
On 30/01/08 02:43, Michael Barton wrote:
> On Jan 29, 2008, at 5:12 PM, Moritz Lennert wrote:
>> On 28/01/08 16:22, Michael Barton wrote:
>>> On Jan 28, 2008, at 5:50 AM, Moritz Lennert wrote:
>>>> On 27/01/08 20:30, Michael Barton wrote:
>>>>> v.univar only works with points. But since it is calculating
>>>>> stats on a field in the attributes table, it should work the same
>>>>> for all vector objects. Can we get rid of the limitation that it
>>>>> only works with points?
>>>> There was some debate [1] about the statistical validity of working
>>>> with the other types, as the way it was programmed, the statistics
>>>> were calculated with weights which corresponded to line length /
>>>> area surface .
>>>> I guess we might want to distinguish between a v.univar which works
>>>> on the actual vector objects from a v.db.univar which works on any
>>>> arbitrary attribute (or combination of attributes). We could write
>>>> a C-replacement of the current v.db.univar script on the base of
>>>> the code I have for the classification algorithms used in v.class.
>>> AFAICT, v.univar does not calculate anything from vector topology,
>>> only from an attribute column.
>>> An attribute is the same whether it's linked to a point, line, or
>>> area.
>> v.univar currently calculates as follows for lines and areas, even
>> though the results are never printed (main.c):
>> [lines:]
>> 206 l = Vect_line_length ( Points );
>> 207 sum += l*val;
>> 208 sumsq += l*val*val;
>> 209 sum_abs += l * fabs (val);
>> 210 total_size += l;
>> [areas:]
>> 270 a = Vect_get_area_area ( &Map, area );
>> 271 sum += a*val;
>> 272 sumsq += a*val*val;
>> 273 sum_abs += a * fabs (val);
>> 274 total_size += a;
>> 285 if ( (otype & GV_LINES) || (otype & GV_AREA) ) {
>> 286 mean = sum / total_size;
>> 287 mean_abs = sum_abs / total_size;
>> So the mean is actually a weighted mean with the area as weight. I don't
>> really no why Radim coded it like this at the time, and I think we
>> should change this so that it just uses unweighted feature counts, just
>> as Roger suggested at the time. Try the attached (untested) patch.
>> One thing that does potentially matter, though, is whether to use the
>> features or the attribute columns as a base. If you have several
>> features with the same cat value, this can make a difference, as in
>> the former case they will all be counted individually, whereas in the
>> latter case, they will only be counted once. If each of the features
>> has an indvididual meaning than the former case seems more correct,
>> but if not (e.g. each island of the Philippines counted separately in
>> a table which lists population by country). Obviously we could just
>> say that it is up to the user to make sure that the map data is
>> correct, i.e. if we take the above example, there should only be one
>> centroid linked to data per country).
>> The way the routines are written in v.class, they take an arbitrary
>> array of floats, so it is up to the individual modules to decide how
>> to create this array.
> This is all very interesting. It is a bit worrisome too. I don't want a
> mean of an attribute column weighted by area unless I specifically ask
> for it. This suggests that people using v.univar may not be getting what
> they think they are getting. I think it is an excellent option, but
> should not be a silent default.
Well, since the results are not printed, the problem doesn't really
exist. The patch I sent doesn't weight at all, just counts features.
> How to count the features is a bit of an issue, but couldn't this be
> left up to the user too--summarize by cat or by individual feature as an
> option?
That's why I think we should have a library function which calculates
stats (i.e. extend what it is the v.class code), and let the modules
deal with such issues.
Moritz
