[GRASS-dev] lib fn to convert int color number to RGB values?
Ivan Shmakov ivan at theory.asu.ru
Thu Jan 31 09:26:50 EST 2008
>>>>> Hamish  <hamish_b at yahoo.com> writes:
 > Glynn:
 >>> The problem is that we have both color_rgb (colors.h) and
 >>> RGBA_Color (gis.h) structures, and we should deprecate one of them
 >>> (probably color_rgb).
 > Ivan:
 >> Although I know no details, having two similar facilities usually
 >> implies having the code base doubled, with only a slight increase of
 >> functionality.
 > RGBA_Color was recently added (as was RGB support for modules' CLI
 > options) so 1) it could be used to pass RGB arround without having to
 > call the display library
	Good!
 > and 2) we could handle a color value of 'none' without needing to
 > pass a separate variable or rely on the palette index number set to
 > -1. Currently the alpha channel is just set to 0 or 255 for
 > full-transparency ('none') or full-opacity.
$ nl -ba include/gis.h
   336	typedef struct
   337	{
   338	    unsigned char r, g, b, a;  /* red, green, blue, and alpha */
   339	} RGBA_Color ;
   340
   341	typedef RGBA_Color RGB_Color;
	s/RGB_Color/RGBA_Color/ ?
