[GRASS-dev] grass6_devel, problems to find gdal library
William Kyngesburye woklist at kyngchaos.com
Sun Jul 6 13:29:27 EDT 2008
Finally had a chance to try it myself.  Looks like changes in r31909
broke it.  The tests are now including gdal.h, yet the GDAL include
path isn't added to the test compile:
configure:7677: gcc -o conftest -Os -arch ppc -arch i386   -arch ppc -
arch i386 -arch ppc -arch i386 conftest.c  -L/Library/Frameworks/
GDAL.framework/Versions/1.5/unix/lib -lgdal 1>&5
configure:7671:18: error: gdal.h: No such file or directory
On Jul 4, 2008, at 12:28 PM, Glynn Clements wrote:
> Massimo Di Stefano wrote:
>> i'm tring to update grass from svn, on osx .
>> the configure find gdal-config
>> but fail to find gdal libraries
>> checking for location of JPEG includes... /Library/Frameworks/
>> UnixImageIO.framework/unix/include
>> checking for jpeglib.h... yes
>> checking for location of JPEG library... /Library/Frameworks/
>> UnixImageIO.framework/unix/lib
>> checking for jpeg_start_compress in -ljpeg... yes
>> checking whether to use GDAL... yes
>> checking for gdal-config... /Library/Frameworks/GDAL.framework/
>> Programs/gdal-config
>> configure: error: *** Unable to locate GDAL library.
> Look in config.log for the command which fails and any error messages
> which it generates.
> Glynn Clements <glynn at gclements.plus.com>
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
