[GRASS-dev] compile error on wx vdigit
Moritz Lennert mlennert at club.worldonline.be
Tue Jul 8 13:31:56 EDT 2008
On 08/07/08 19:04, Martin Landa wrote:
> Hi,
> cd gui/wxpython/vdigit
> rm grass6*
> make clean;make
> Should help.
Yep. Thanks !
Moritz
> Martin
> 2008/7/8 Moritz Lennert <mlennert at club.worldonline.be>:
>> I get the following error trying to compile wxpython vdigit:
>> ~/SRC/GRASS/grass_trunk/gui/wxpython/vdigit$ make
>> c++ -I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -g
>> -O2   -fPIC -I/usr/include -I/usr/include/python2.4 -I/usr/include/python2.4
>> -fno-strict-aliasing -DNDEBUG -g -O2 -Wall -Wstrict-prototypes
>> -I/usr/lib/wx/include/gtk2-unicode-release-2.8 -I/usr/include/wx-2.8
>> -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D_LARGEFILE_SOURCE=1 -D__WXGTK__
>> -pthread   -DPACKAGE=\""grasslibs"\"
>> -I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -o
>> OBJ.i486-pc-linux-gnu/grass6_wxvdigit_wrap.o -c grass6_wxvdigit_wrap.cpp
>> cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
>> Ada/C/ObjC but not for C++
>> grass6_wxvdigit_wrap.cpp: In function 'PyObject*
>> _wrap_DisplayDriver_UpdateSettings(PyObject*, PyObject*)':
>> grass6_wxvdigit_wrap.cpp:11008: error: no matching function for call to
>> 'DisplayDriver::UpdateSettings(long unsigned int&, bool&, long unsigned
>> int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long
>> unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&,
>> long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&,
>> bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned
>> int&, int&)'
>> driver.h:210: note: candidates are: void DisplayDriver::UpdateSettings(long
>> unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long
>> unsigned int, bool, long unsigned int, int)
>> make: *** [OBJ.i486-pc-linux-gnu/grass6_wxvdigit_wrap.o] Erreur 1
>> Any hints ?
>> Moritz
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
