[GRASS-dev] Re: r.series, r.terraflow, simwe
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Jul 9 18:22:50 EDT 2008
On Wed, 9 Jul 2008, Glynn Clements wrote:
>> it before Will moves r.terraflow into the iostream directory as
>> suggested by Paul.
> Can you provide details?
Will is working on a new r.viewshed module which uses the same iostream
C++ library as r.terraflow. To avoid code duplication I suggested this
layout:
Have a subdirectory:
raster/iostream/
and within that lib/ r.terraflow/ r.viewshed/
One copy of the library in the lib directory - it compiles into a static
library which is then linked in by r.terraflow and r.viewshed.
This is subject to revision/better ideas of course - when Will has the
r.viewshed code ready (I haven't seen it) maybe we can experiment with
it in grass-addons in the first instance.
Paul
