[GRASS-dev] Re: nvizlib compile error
Thu Jul 10 00:17:20 EDT 2008
Michael Barton wrote:
> Are we at a place yet where I can compile and test this on a Mac,
> given it's location of OpenGL in the agl directory?
The code won't compile on a Mac at present.
AFAICT, it requires at least:
    /* TODO */
-    rwin->displayId = aglChoosePixelFmt(GDHandle *dev, int ndev, attributeList);
+    rwin->displayId = aglChoosePixelFmt(NULL, 0, attributeList);
-    rwin->contextId = aglCreateContext(rwin->display, NULL);
+    rwin->contextId = aglCreateContext(rwin->displayId, NULL);
    /* create win pixmap to render to (same depth as RootWindow) */
-    rwin->pixmap = NULL; /* TODO */
+    rwin->pixmap = <no idea what should go here, but it ain't NULL>;
There is some information on AGL at:
[1]	http://www.mesa3d.org/brianp/sig97/agl.txt
[2]	http://www.mesa3d.org/brianp/sig97/compare.htm
but I don't know how much of that refers to "classic" rather than OSX.
There's a lot more information in visualization/nviz/src/togl.c, but
it doesn't include creating off-screen pixmaps.
I also note:
[3]	http://www.iua.upf.es/~ggeiger/redbookhtml/apc.html
	Off-screen Rendering
	To render off-screen, first create an off-screen graphics
	world in the usual way, and pass the handle into
	aglCreateAGLPixmap().
Good luck on figuring out what "the usual way" is ;)
A Google search for aglCreateAGLPixmap produces exactly 7 hits; I've
just posted three of them, and the other 4 seem to be duplicates of
[1] and [3].
IOW, everything that mentions aglCreateAGLPixmap seems to assume that
you are already familiar with normal (non-OpenGL) Mac GUI programming.
In any case, it's going to require some amount of trial and error from
someone with a Mac.
