[GRASS-dev] Re: [GRASS-user] v.out.ogr multiple
Moritz Lennert
mlennert at club.worldonline.be
Fri Jul 11 12:49:53 EDT 2008
Moving this over to grass-dev: is there a gisprompt for directories
instead of files ?
Also, where can one see all the defined gisprompts for g.parser ?
Moritz
On 09/07/08 13:26, Gabriele N. wrote:
> Thanks Moritz.
> I have made some improvements.
> I give you an example and the new script. Now I export all vectors with
> name that starts with "foglio_1"
> But I do not know how to select a folder where to export the shapes. Now,
> only works if I enter the path by hand or select from a graphical user
> interface a file in the folder (prova).
> But it begins to work :-)
> Still suggestions?
> Thanks
> Gabriele
> http://www.nabble.com/file/p18359390/Schermata-v.out.ogr_multiplo.sh.png
> http://www.nabble.com/file/p18359390/v.out.ogr_multiplo.sh
> Moritz Lennert-2 wrote:
>> On 09/07/08 10:42, Gabriele N. wrote:
>>> Hi Moritz.
>>>> On 08/07/08 22:33, Gabriele N. wrote:
>>>>> Hello.
>>>>> I want to create a script bash (GUI) to export many vector in shapefile
>>>>> having the opportunity to decide which export layer (0, 1, 2) and
>>>>> type=line,area ecc..
>>>> Does this mean interactive decision layer by layer, or that the module
>>>> should allow for entering layer and type as an option ?
>>>>> I would also like to know if you can use the characters as' * 'to be
>>>>> able
>>>>> to
>>>>> export all instance vector starting with' nome_vector ....'.
>>>>> There is already some scripts? If not, I started to write something in
>>>>> bash
>>>>> but I am in difficulty.
>>>> It will have to be something like:
>>>> for map in `g.mlist type=vect pattern=$GIS_OPT_PATTERN
>>>> do
>>>> v.out.ogr $map type=$GIS_OPT_TYPE layer=$GIS_OPT_LAYER
>>>> done
>>>> where GIS_OPT_PATTERN would be something like 'nome_vector*'
>>>> If you need to automatically decide which layers and types to export,
>>>> you might be able to do some grep/awk magic with v.category -g $map
>>>> option=report.
>>>> Moritz
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> I would like to insert layer and type as an option.
>>> Attached is what I have done (GUI and script). However, there are errors.
>>> http://www.nabble.com/file/p18356967/Schermata-v.out.ogr_multiplo.sh.png
>>> http://www.nabble.com/file/p18356967/v.out.ogr_multiplo.sh
>>> Where I wrong?
>> It would be easier to help you if you gave us more information about the
>> errors...
>> But from looking at your script, I already see this:
>> for map in g.mlist type=vect pattern=$GIS_OPT_PATTERN
>> should be:
>> for map in `g.mlist type=vect pattern=$GIS_OPT_PATTERN`
>> note the backticks (`)
>> and then
>> v.out.ogr input=${map} ...
>> should be v.out.ogr input=$map
>> Moritz
>> Moritz
