[GRASS-dev] trying to compile wxPython NVIZ
Tue Jul 15 03:29:14 EDT 2008
Martin Landa wrote:
> >> Anyway, off-screen rendering is still unsolved on Mac. To try wxGUI
> >> Nviz extension, you should be able to compile nvizlib without rendec.c
> >> (which is not needed for wxGUI).
> > If you have to explicitly disable render.c, that suggests that
> > something needs to be conditionalised. The code should at least
> > compile on all platforms, even if it doesn't work.
> > If you can't fix the compilation issues yourself, please post the
> > error messages to the list.
> I just don't have access to Mac to find out how to make off-screen
> rendering working on this platform...
I'm not talking about getting off-screen rendering working; I'm
talking about gettting lib/nviz compile. If it fails to compile, you
can't even test the parts which should work.
