[GRASS-dev] Python Scripting
Michael Barton
michael.barton at asu.edu
Wed Jul 16 11:32:38 EDT 2008
On Jul 16, 2008, at 1:28 AM, Glynn Clements wrote:
> Michael Barton wrote:
>>> subprocess.call([
>>> "v.extract",
>>> "input=%s" % os.getenv("GIS_OPT_INPUT"),
>>> "output=%s_%s" % (os.getenv("GIS_OPT_OUTPUT"), i),
>>> "type=point", "layer=1", "new=-1", "list=%s" % i])
>> Glynn,
>> How do subprocess.call and subprocess.Popen compare for running GRASS
>> commands from inside Python scripts? Is call easier than Popen in
>> this
>> context?
> subprocess.call is a convenience function for the simplest case where
> you don't need to interact with the child process beyond waiting for
> it to finish; it's defined as:
> def call(*args, **kwargs):
> """Run command with arguments. Wait for command to complete,
> then
> return the returncode attribute.
> The arguments are the same as for the Popen constructor.
> Example:
> retcode = call(["ls", "-l"])
> return Popen(*args, **kwargs).wait()
> It behaves like system(), but without the shell (so you don't have to
> deal with /bin/sh syntax vs cmd.exe syntax, spaces and other shell
> metacharacters in argument values, etc).
> It's roughly equivalent to os.spawnvp(P_WAIT,...), which is deprecated
> in favour of the subprocess module. Most of the other os.* functions
> are similarly deprecated, except for the os.exec* family (for which
> the main use is executing g.parser).
> Glynn Clements <glynn at gclements.plus.com>
This seems very handy for a lot of basic GRASS scipting, including
replacing bash scripts with Python ones--something that I'd like to
start on soon and would encourage anyone wanting to get experience in
Python to try.
Michael
