[GRASS-dev] Python Scripting
    Michael Barton
    michael.barton at asu.edu
    Fri Jul 18 01:10:05 EDT 2008
Hi Dan,
This sounds intriguing. What we need to ask is what would this gain us
and how much work would it take.
Michael
On Jul 17, 2008, at 9:00 AM, <grass-dev-request at lists.osgeo.org> wrote:
> Date: Thu, 17 Jul 2008 11:23:58 -0400
> From: "Dan D'Alimonte" <dan at dalimonte.ca>
> Subject: Re: [GRASS-dev] Python Scripting
> To: grass-dev at lists.osgeo.org
> Message-ID: <487F640E.6030704 at dalimonte.ca>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> I'm curious if any though has been given to developing an actual GRASS
> library for Python that goes beyond calling executables with system
> calls?
> I'm thinking about a model that encapsulates the GRASS environment and
> allows for both low-level processing like the C library, and high-
> level
> use of existing modules like shell scripts.
> I'll admit I have not given this a lot of though, but a hypothetical,
> and  quickly thought-out, example could be something like:
> from grass import module, layer, cell, parser
> def r_add(inLayers, outLayer):
> 	for outCell in outLayer.cells:
> 		sum = cell(type=outLayer.cellType)
> 		for l in inLayers:
> 			c = l.getCellAtSameLocation(outCell)
> 			if c.value==cell.null:
> 				sum.value = cell.null
> 				break
> 			sum.value += c.value
> 		outCell.value = c.value
> 	outLayer.commit()
> if __name__ == "__main__":
> 	# Set up module information here
> 	# Set up and run parser
> 	# Open input layers
> 	# Create new layer for output
> 	# call r_add()
> 	# close layers
> I don't know if this would even be feasible, but I think it would
> make a
> nice addition to GRASS's Python support. If done right it would even
> allow other python-based GRASS modules to be called-on without
> having to
> make a system-call (eg. from raster_add import r_add).
> As to existing modules, what about a helper function to access then?
> module.executeModule( name="r.stats", options={ "input":
> "elevation.dem,slope,aspect", "fs": ",", "output": "elev.csv"},
> flags=["q", "1", "n", "g"] )
> It was just a thought, and would require a lot more thought and work
> to
> design properly. I, frankly, do not have enough understanding of GRASS
> internals to even know where to begin.
