[GRASS-dev] Re: SoC Report: v.buffer/v.parallel reimplementation
Росен Матев
r.matev at gmail.com
Sat Jul 19 20:03:43 EDT 2008
This week, I've done the implementation of functions which create the
graph I mentioned about. I've modified all nessessary code to use
them. There are some bugs which I'm dealing with at the moment. Next
week, I'll fix the two bugs (which I found some time ago) in
parallel_line(). I already thought up how to do that. Next week you
should expect the brand new v.buffer showing up in developers ml.
There are no blocks at moment.
Rosen Matev
