[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Michael Barton
michael.barton at asu.edu
Tue Jul 22 11:44:43 EDT 2008
On Jul 22, 2008, at 5:07 AM, Glynn Clements wrote:
> Michael Barton wrote:
>> After some delays, I managed to recompile GRASS 7 with CFLAGS="-arch
>> i386 -g", etc so that gdb would produce useful output, and with TclTk
>> 8.5 aqua for Mac. Running nviz in gdb gives the results below.
>> Hopefully these are more helpful. It freezes at the last line.
>> Program received signal EXC_BAD_ACCESS, Could not access memory.
>> Reason: KERN_PROTECTION_FAILURE at address: 0x00000024
>> 0x0001702d in Togl_CreateWindow (tkwin=0x1fdb608, parent=30857160,
>> instanceData=0x758db0) at togl.c:2338
>> 2338 if (!aglSetDrawable(togl->aglCtx,
> The complete line is:
> # if defined(TOGL_AGL)
> ((MacDrawable *) (window))->toplevel->grafPtr
> # else
> ((MacDrawable *) (window))->toplevel->portPtr
> # endif
> togl and togl->aglCtx are known to be non-NULL (otherwise it would
> have crashed before then). Can you try the following:
> print ((MacDrawable *) (window))
> print ((MacDrawable *) (window))->toplevel
> print ((MacDrawable *) (window))->toplevel->grafPtr
I'm assuming that you mean to enter these lines in gdb. Here is the
result.
(gdb) run -f $GISBASE/etc/nviz2.2/scripts/nviz2.2_script -q
Starting program: /Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/
nviz2.2/nviz -f $GISBASE/etc/nviz2.2/scripts/nviz2.2_script -q
Reading symbols for shared libraries ++++++++++++++++++++++
...................................................................................... done
Reading symbols for shared libraries . done
Reading symbols for shared libraries ....... done
Reason: KERN_PROTECTION_FAILURE at address: 0x0000002c
0x0001702d in Togl_CreateWindow (tkwin=0x1d89608, parent=30902152,
instanceData=0x7579c0) at togl.c:2338
(gdb) print ((MacDrawable *) (window))
No symbol "MacDrawable" in current context.
(gdb) print ((MacDrawable *) (window))->toplevel
(gdb) print ((MacDrawable *) (window))->toplevel->grafPtr
Michael
