[GRASS-dev] matplotlib again
Michael Barton michael.barton at asu.edu
Tue Jul 22 21:07:26 EDT 2008
While waiting for an answer from the developer of one of the wxPython
mixins on why it doesn't work, I spent a little time looking at
MatPlotLib again.
Sometime back, I'd mentioned this as a potentially useful library to
include with a Python-enabled GRASS because it can create a rich array
of high-quality graphs and charts (and even maps). One of the issues
raised was that it needs to be used within a GUI environment meaning
that the GUI can do things that the command line can't. Not long ago,
while talking with a Python-using colleague, I mentioned MatPlotLib
and he said, 'of course it can be used from the command line to create
a graphic file; I do it all the time'. So I looked into to it today
while recovering from a wisdom tooth extraction. Indeed, it can be put
into a script to be run from the command line and output a normal
graphic file, like a *.png. Here is a link on how to do it.
<http://www.dalkescientific.com/writings/diary/archive/2005/04/23/matplotlib_without_gui.html
This cookbook entry is 3 years old. Along with the Agg backend
mentioned in the cookbook (for png), new backends for MatPlotLib
include Cairo (for pdf, png, ps, svg, and svgz), dedicated pdf and ps,
and dedicated svg--in addition to GUI backends for wx, TclTk, and Qt.
We could use it to replace dedicated GRASS code for creating graphs
like d.histogram and build it into scripts that now call gnuplot. It's
worth checking out at <http://matplotlib.sourceforge.net/>. It could
be used within the GUI of course, but also within scripts to output to
graphic files.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080722/6eb9758b/attachment.html
