[GRASS-dev] Re: Line of Sight Update
Will willster3021 at gmail.com
Wed Jul 23 09:42:06 EDT 2008
All of that is already in place and working.  (Well, I don't know if
curvature is working - all the data I have here is in the wrong projection
to work with curvature, but i ported the code from r.los, so hopefully it
should work as expected)  Right now, I'm having some issues with it
determining correctly which mode it should be in (internal memory, external
memory, or a variant of external memory where we distribute sectors) but I
have been running a lot of tests, and hopefully this will be one of the last
bugs to work out.
- Will
On Wed, Jul 23, 2008 at 6:35 AM, Paul Kelly <paul-grass at stjohnspoint.co.uk>
wrote:
> On Wed, 23 Jul 2008, Markus Neteler wrote:
>  On Wed, Jul 9, 2008 at 8:11 PM, Will <willster3021 at gmail.com> wrote:
>> It is done exactly the way you mentioned in the other email, finding the
>>> radius of the elipsoid and reducing the elevatin of the cell that you are
>>> looking at depending on the distance it is away from the viewpoint.  The
>>> way
>>> r.los does it is they have a flag that you set if you want the curvature
>>> to
>>> be considered, though I can impliment it for all calculations without a
>>> flag
>>> if we think that will be better- any input from the list on this?
>> I would keep the flag if there aren't too many.
> Yes, agreed it should be optional - someone might want to use the module in
> an XY environment without large-scale real-world considerations such as
> earth curvature.
> Paul
-Will
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080723/77bc576a/attachment.html
