[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Michael Barton michael.barton at asu.edu
Wed Jul 23 20:18:44 EDT 2008
On Jul 23, 2008, at 5:16 PM, Glynn Clements wrote:
> Michael Barton wrote:
>> I don't know enough about make to offer suggestions. But if you get a
>> procedure sorted out, I'm happy to try it.
> The only way that we will get a procedure sorted out is if you try
> stuff until you find something that works.
True enough. But I need to know what to change. From my perspective,
the suggestions have been kind of cryptic. I know that you and William
know what you're referring to, but I need a bit more detailed
instruction as to what to change, and where. I'm willing to try
various things however to see if anything works OK.
Michael
