[GRASS-dev] d.thematic.area: need for a bit of help in C-programming/debugging
Moritz Lennert mlennert at club.worldonline.be
Thu Jul 24 20:28:20 EDT 2008
On 24/07/08 21:55, Michael Barton wrote:
> On Jul 24, 2008, at 12:25 PM, <grass-dev-request at lists.osgeo.org> wrote:
>> Date: Thu, 24 Jul 2008 18:46:31 +0200
>> From: Moritz Lennert <mlennert at club.worldonline.be>
>> Subject: [GRASS-dev] d.thematic.area: need for a bit of help in
>> To: grass-dev <grass-dev at lists.osgeo.org>
>> Message-ID: <4888B1E7.30208 at club.worldonline.be>
>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>> Hello,
>> I'm having a problem with the d.thematic.area module I just committed in
>> a modified version.
>> When I use the discontinuities algorithm for calculating the class
>> breaks, I get segmentation faults, depending on the number of classes I
>> ask for and on the variable I try to class.
> Moritz,
> Because I've been trying to help work out how to compile GRASS in aqua
> TclTk, I don't have a version that can run this for testing at the
> moment. Is this in 6.4 as well as trunk? I have an x11 version there. If
> not, I'll try to do an x11 version of trunk to test this when you get
> this new issue fixed. Thanks again.
I've only committed to trunk. I feel this code is still too fresh to
enter 6.4.
Moritz
