[GRASS-dev] Re: [GRASS GIS] #234: v.type, v.type.sh,
GUI and WinGRASS
trac at osgeo.org
Fri Jul 25 15:22:52 EDT 2008
#234: v.type, v.type.sh, GUI and WinGRASS
Reporter: msieczka | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: All
Comment (by glynn):
Replying to [ticket:234 msieczka]:
> Autogenerated v.type wxGUI still suffers from an old bug described on
[1]. The v.type.sh workaround will not work on Windows without msys. Would
a Python replacement do?
Yes (assuming that you have python).
Alternatively, we could hack v.type to omit the various ->options fields
if argv[1] is --ui, --tcltk or --interface-description.
> Or is it possible to fix the problem instead of a workaround?
Modifying the way that the GUI handles the case where opt->multiple is
true and opt->options is set is possible, but it would be inconvenient for
the other modules which don't care about order (i.e. where the value is a
set instead of a list).
To support both sets and lists, we would need to extend the semantics of
the Option structure, extend the parser, and extend both GUIs.
Ticket URL: <http://trac.osgeo.org/grass/ticket/234#comment:1>
