[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Michael Barton
michael.barton at asu.edu
Sun Jul 27 15:57:48 EDT 2008
Getting this worked out for building GRASS on the Mac is important and
I'm very glad that you guys are working this out so that it can be
built more easily in more flexible ways.
This question concerns binary users, like those who will want to
download a binary from William's site.
In the direction you are heading, will it...
1) be necessary for binary users to install a correct version of TclTk
on their system if necessary? Certainly pre-Leopard versions of Mac
OSX only have 8.3 and 8.4 (I'm still not sure where my 8.5 aqua
versions came from on both my Leopard systems), and 8.4 is the crummy
aqua version that doesn't work well.
2) be necessary (or possible) for binary packagers to include the
'right' version of TclTk with the Mac package to make sure it works as
compiled?
Michael
On Jul 27, 2008, at 12:17 PM, Glynn Clements wrote:
> William Kyngesburye wrote:
>>>> Of course, some extra detection logic is needed to check for the
>>>> frameworks in /Library/Frameworks, then /System/Library/Frameworks.
>>> configure doesn't autodetect paths, it only confirms that any paths
>>> specified by the user work. If a path needs to be passed onto the
>>> compiler or linker, the user has to supply it.
>> Well, for using the system paths, a path is still needed to set the
>> include flags, but not for the -F path.
>> Like -L flags, they are unnecessary for default system paths (/usr/
>> lib, or /System/Library/Frameworks and /Library/Frameworks), and can
>> cause trouble in the search order (on OSX) if used (you get the
>> system
>> framework when you wanted a custom-build framework).
>> If we don't autodetect the path, but need a path for the headers,
>> then
>> configure should not set -F if the user uses one of the system paths.
>>> I take it that -framework is limited to the linker? I.e. the
>>> compiler
>>> still needs explicit -I flags?
>> -framework is like -L, but for frameworks - yes, a linker flag only.
> AFAICT, it's like -l rather than -L.
>> There is a way to include headers without -I flags, but it requires
>> changes to the sources, and it doesn't work for PrivateHeaders.
>> #include <Tk/tk.h>
>> looks for tk.h in the Tk.framework/Headers.
> Are you sure that it doesn't work for PrivateHeaders; this suggests
> otherwise (under the documentation of -F):
> http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/gcc.1.html
> If it does work for PrivateHeaders, I would suggest using the
> framework syntax for the headers (then, -F should work for both the
> libraries and headers).
>>>> Also, the framework option should be rejected if opengl is not
>>>> aqua.
>>> It's still meaningful if OpenGL is disabled.
>> If linking tcltk is only for NVIZ, then tcltk should match the opengl
>> setting. The tcltk framework is always aqua, you can't build tcltk
>> x11 as a framework.
> Tcl/Tk isn't only for NVIZ. v.digit and the form library also link
> against it.
> Glynn Clements <glynn at gclements.plus.com>
