[GRASS-dev] PYTHONPATH question
Michael Barton michael.barton at asu.edu
Tue Jul 29 12:59:59 EDT 2008
On Jul 29, 2008, at 9:54 AM, Michael Barton wrote:
> On Jul 29, 2008, at 9:37 AM, William Kyngesburye wrote:
>> [coming out of lurking on this one]
>> It looks like, when run from a python script in GRASS, you're
>> getting the system python.
>> Yet, when you run python itself from GRASS, you get the python.org
>> Python.  What is the shebang line (first line) in your python
>> script, it may be pointing to the system python?
>> On Jul 27, 2008, at 7:40 PM, Michael Barton wrote:
>>>> Is "python" the actual executable, or is it a front-end script?
>>> /usr/bin/python and /usr/local/bin/python are symlinks to /Library/
>>> Frameworks/.../python2.5, which is an executable. I've checked and
>>> this is the only "python" in my path
>> /usr/bin/python should be a symlink to the SYSTEM python.
> Weird. When I do 'show original' for /usr/bin/python, it shows as a
> symlink to
> /System/Library/Frameworks/Python.framework/Versions/2.5/bin/python
> ...which is a symlink to /System/Library/Frameworks/Python.framework/
> Versions/2.5/bin/python2.5
Note that when I do a 'show original' for both symlinks /usr/bin/
python and /usr/local/bin/python, they both go to the same place:
But one calls the System 2.5.1 and the other one calls the MacPython
2.5.2
Michael
