[GRASS-dev] GRASS 7 development started
Markus Neteler neteler at osgeo.org
Thu Jul 31 16:59:04 EDT 2008
On Thu, Jul 31, 2008 at 6:57 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> do you have the ultimate "indent" line for me?
>> > indent -bad -bap -bbb -br -bli0 -bls -cli0 -ncs -fc1 -hnl -i4 \
>> >       -nbbo -nbc -nbfda -nbfde -ncdb -ncdw -nce -nfca -npcs -nprs \
>> >       -npsl -nsc -nsob -saf -sai -saw -sbi0 -ss -ts8 -ut
>> I have done a test run locally and came across a problem:
>> cd visualization/nviz/src
>>        -npsl -nsc -nsob -saf -sai -saw -sbi0 -ss -ts8 -ut togl_flythrough.c
>> indent: togl_flythrough.c:609: Warning:old style assignment ambiguity
>> in "=-".  Assuming "= -"
> These warnings are harmless. K&R C allowed "=-", "=+" etc as aliases
> for "-=", "+=", etc. But I have never even heard of anyone
> encountering this syntax in actual code, and certainly haven't seen it
> myself. Also, it only works with K&R-style compilers; gcc doesn't even
> have an option to support it.
OK, so I'll ignore those.
>> indent: togl_flythrough.c:956: Error:Unexpected end of file
> This is caused by the "README" in the "#if 0 ..." block at the top of
> the file. If you remove that block, the error goes away.
Done. Now README.flythrough also in 6.4.
> Even code which is disabled with "#if 0 ..." should at least parse as
> C code. Otherwise, it tends to mess up formatting and syntax
> highlighting in text editors (which usually just ignore preprocessor
> directives).
>> Additionally, there are:
>> indent: ./lib/vector/dglib/misc-template.c:546: Error:Stmt nesting error.
>> indent: ./lib/vector/dglib/misc-template.c:623: Error:Unmatched 'else'
>> indent: ./lib/vector/dglib/misc-template.c:649: Error:Stmt nesting error.
> That's caused by putting unmatched braces inside a #if. Again, this
> tends not to work with tools which operate upon source code.
> Note that misc-template.c isn't actually used.
>> indent: ./swig/perl/grass_wrap.c:1064: Error:Stmt nesting error.
> Again, unmatched braces inside #if. But:
> 1. That file shouldn't even be under version control, as it isn't a
> source file (it's an intermediate file, generated by SWIG).
> 2. It shouldn't be indent-ed (or modified in any way, as it's
> auto-generated).
> 3. It should arguably have a .cc extension as it contains C++ code.
If 1. solves it, also 2. and 3. go away.
>> and several warnings like
>> indent: ./lib/sites/sites.c:859: Warning:old style assignment
>> ambiguity in "=-".  Assuming "= -"
>> and
>> indent: ./lib/rst/interp_float/vinput2d.c:75: Warning:old style
>> assignment ambiguity in "=*".  Assuming "= *"
> Harmless, see above.
Perfect.
>> Analysing one of the 'Assuming "= -"' warnings, it turns out that:
>>                     site->cattype=-1;
>> is changed to
>>                     site->cattype = -1;
>> but it should be
>>                     site->cattype =- 1;
> No, it should be "site->cattype = -1;", as it's assigning negative
> one, not decrementing.
>  This is sites/s.in.ascii/get_site.c:130, right? I'm quite
> certain that it really should be assigning -1, not decrementing.
Ok.. there are a couple of those.
> If was really supposed to be a decrement operation, it would need to
> be either:
>        site->cattype -= 1;
> or:
>        site->cattype--;
> in order to work with existing compilers.
>> Can we trap this? Otherwise we can run it locally and fix all warnings
>> manually in SVN before running the global automated indenting.
> You can verify that the indentation isn't changing the semantics of
> the code by compiling everything[1] without -g and with -DNDEBUG,
> before and after indenting, and comparing the .o files.
Mhh, sounds like quite some work.
> [1] If you want to be 100% certain, you will need use all of the
> --with-<package> switches (which means installing all optional
> dependencies), and on multiple platforms.
Perhaps I'll take out those (few) files for now and leave them.
> When I tried it on Linux with everything except MySQL, SQLite and
> OpenDWG, I didn't find any mismatches. That probably accounts for 99%
> of the code, so the chances are slim that there are any problems in
> the fraction of the code which didn't get compiled.
You mean that you indented and compiled all successfully?
So we can go ahead?
Markus
