[GRASS-dev] GRASS 7 development started
Wed Jun 11 00:36:49 EDT 2008
Moritz Lennert wrote:
> > Hamish:
> >>>> Any thoughts on keeping the inter-branch svn merge
> >>>> effort low?
> > Glynn:
> >>> Don't merge?
> >>> Eventually, 7.x and 6.x are going to diverge by more
> >>> than just formatting.
> > but forking isn't a very nice solution.
Nice or not, it's inevitable.
> Could you elaborate on why you fear forking here ? We are planning a
> quite radical revamp of the code, so by definition the versions will be
> incompatible at one stage. But I wouldn't call this "forking" ?
It isn't "forking" insofar as 6.x is nearing the end of its lifespan.
It's normally only considered a fork if both versions will persist
indefinitely.
