[GRASS-dev] proper v.parallel behavior on strange input
Wolf Bergenheim wolf+grass at bergenheim.net
Wed Jun 18 08:42:50 EDT 2008
I have 2 solutions depending on what you need. Solution A stays true to
the direction of the line and follows it regardless of loops and what not.
Solution B will not cross the line. To get this solution you will
probably have to find all the internal intersections of the line and at
each intersection go so that you don't cross the line. Solution A is not
concerned with intersections. It would be cool if v.parallel can support
both, maybe via a switch.
--Wolf
On 17.06.2008 00:37, Росен Матев wrote:
> And here is the input
> Absently,
> Rosen
> On Tue, Jun 17, 2008 at 12:31 AM, Росен Матев <r.matev at gmail.com> wrote:
>> Hi again,
>> This time I'm challenging you with another strange line. What should
>> v.parallel output, with options dist=7, side=left and straight corners
>> (round corners), given that input? I won't give you current behavior
>> of v.parallel2 (or other suggestions), cause I don't want to influence
>> on your opinion.
>> Rosen
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
<:3 )---- Wolf Bergenheim ----( 8:>
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080618/653bb8a6/v.parallel_problems_lines-0001.png
