[GRASS-dev] Re: [GRASS GIS] #193: metes and bounds converter
GRASS GIS trac at osgeo.org
Sat Jun 21 06:26:48 EDT 2008
  Reporter:  GrandmaDOG   |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  7.0.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:  metes bounds parcels
Comment (by hamish):
 does GRASS's m.cogo module help? or could it be expanded to be more
 useful?
   http://grass.osgeo.org/grass63/manuals/html63_user/m.cogo.html
 "A simple utility for converting bearing and distance measurements to
 coordinates and vice versa."
 I suppose a good check for the module would be to run it for a closed loop
 and check that the endpoint matches the starting point. Probably have to
 do that with fake data as what is printed on a survey sheet might not be
 exact which may lead to small circuit errors.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/193#comment:1>
