[GRASS-dev] cannot build gdal-grass
Sun Jun 22 14:23:33 EDT 2008
Maciej Sieczka wrote:
> gdal-grass 1.4.3 refuses to build against GDAL 1.5.2 r14751 and GRASS
> 6.4 r31801.
> checking for G_asprintf in -lgrass_gis... no
> configure: error: --with-grass=/usr/local/grass-6.4.svn requested, but
> libraries not found! Perhaps you need to set LD_LIBRARY_PATH to include
> /usr/local/grass-6.4.svn/lib
> What could be wrong? This used to work couple of days ago.
Look in config.log for the actual error message.
When configure says that a library is "not found", it means that it
couldn't link against it. There are a whole load of reasons why that
might be the case.
