[GRASS-dev] WinGRASS Wiki Hacking
Wed Jun 25 09:52:43 EDT 2008
Glynn Clements wrote:
> Frank Warmerdam wrote:
>> It includes a somewhat half-baked WinGRASS build I prepared myself
>> several months ago, based on the wingrass build notes at the time.
>> Amoung other things, it proves that a MingW built GRASS can use
>> a VC7.1 built GDAL.
> Alas, I'm finding that isn't the case. Any and all attempts to
> configure GRASS using the OSGeo4W libraries fail with:
> 	undefined reference to `GDALOpen'
> [This is after I've constructed a working gdal-config from
> gdal-config.tmpl.]
> I have tried both linking against the import library with:
> 	-L/c/OSGeo4W/lib -lgdal_i
Glynn,
The gdal-config distributed in /c/osgeo4w/bin should return this for
gdal-config --libs:
warmerda at gdal3200% gdal-config --libs
/C/osgeo4w/lib/gdal_i.lib
I use this configure line:
./configure \
         --prefix=c:/warmerda/grassbld/bld \
         --bindir=c:/warmerda/grassbld/bld/bin \
         --with-includes=/c/warmerda/grassbld/forgrass/include \
         --with-libs=/c/warmerda/grassbld/forgrass/lib \
         --with-gdal=/c/osgeo4w/bin/gdal-config \
         --with-proj-includes=/c/osgeo4w/include \
         --with-proj-libs=/c/osgeo4w/lib \
         --with-proj-share=/c/osgeo4w/share/proj \
         --with-cxx --without-jpeg --without-tiff \
         --without-postgres --with-opengl=windows --without-fftw --without-x \
         --enable-x11=no --enable-shared=yes \
         --with-tcltk-includes=/c/tcl/include \
         --with-tcltk-libs=/c/tcl/bin
To get proj to work, I found I had to copy /c/osgeo4w/lib/proj_i.lib to
/c/osgeo4w/lib/libproj.a.  If you file an OSGeo4W ticket on this, I would
be willing to make it a standard part of the proj package for OSGeo4W.  But
in the meantime it is pretty easy to take the .lib stub libraries and copy
them somewhere as .a files for use.
As you may note above, I think PROJ and GDAL were the only two subcomponents
I got from OSGeo4W during the build.  I would hope in the future to get more
but at this point I sort of ran out of steam.
> and directly against the DLL with:
> 	-L/c/OSGeo4W/bin -lgdal15
> I also had to remove the msvcrt.dll from the bin directory, as that
> caused -L/c/OSGeo4W/bin to fail (even if you didn't actually use any
> libraries) due to multiple definitions of _onexit() and atexit().
I think you are barking up the wrong tree here, and there should be
no reason to remove msvcrt.dll from the bin directory.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
