[GRASS-dev] g.list: extra whitespace issue
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Mar 2 13:30:15 EST 2008
On Mon, 3 Mar 2008, Ivan Shmakov wrote:
>>>>>> Ivan Shmakov <ivan at theory.asu.ru> writes:
> IS> [...]
> >> As for the padding problem, I believe that a more generic solution
> >> should be implemented.
> > Such as the following (rather obscure, though actually obvious)
> > one.
> 	Since there were no objections, and since the extra whitespace
> 	may trigger extra linebreaks in the W32 ``console'' window:
> $ g.list
> bar					baz
> foo					qux
> 	I've now committed the change:
Thanks Ivan. The orginal code was mine (a "DIY" solution), and I was aware
of the problem with the ugly linebreaks on Windows, but hadn't yet
investigated it further. FWIW I thought no space after the last item on
a line, rather than no no space when there is only one item on a line,
was the obvious course of action to pursue, but I'm sure the code from GNU
ls achieves the same even better than hacking my code would.
Paul
