[GRASS-dev] Re: [GRASS-user] How to find out an angle between to points on the map (for r.plane, r.lake)
Hamish hamish_b at yahoo.com
Mon Mar 3 02:41:04 EST 2008
Michael:
> > I just tried to check out any updates to d.measure and found that
> > it doesn't run on my Mac. It produces a bus error. I don't need
> > it, but folks should be aware of this.
Hamish:
> the code for it hasn't changed in 10 months
Dylan:
> I do not have access to a Mac, but the module seems to compile and
> run fine on Linux x86.
> Could it be the call to atan2() -- perhaps the math library is not
> accessed the same way on Mac OS X ?
I have just tested here using William's 6.3 binaries from a few weeks
ago and I too get a Bus error when trying to start d.measure. (Minimac
+ OSX 10.4)
gdb is not installed on the lab Macs and I'm not sure how to set things
to have it produce a core dump to the terminal upon errors.
g.gisenv set="DEBUG=5"  doesn't give any additional output.
one thing I forgot to try was a simple 'd.measure --help'
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
