R: [GRASS-dev] winGRASS RC5 Fails on Creating a New Projection
marco.pasetti at alice.it marco.pasetti at alice.it
Mon Mar 3 03:46:16 EST 2008
Hi Markus,
I tried to use g.proj from command line and it doesn't report errors... but reopening GRASS I don't have the new location!
I should better learn GRASS ;-)
I'll retry later, now I have to recompile GRASS with the new built (not installed) Tcl version;
About that, I'm still confused about the release: Paul tells (and I trust him) that 8.15 is OK, while recently on the list I found lots of messages telling that it has problem with latest GRASS release.
What do you think about?
Regards,
Marco
Da: neteler.osgeo at gmail.com per conto di Markus Neteler
Inviato: dom 02/03/2008 1.10
A: marco.pasetti at alice.it
Oggetto: Re: [GRASS-dev] winGRASS RC5 Fails on Creating a New Projection
Hi Marco,
could you try the same on command line?
Markus
On Sat, Mar 1, 2008 at 6:59 PM, Marco Pasetti <marco.pasetti at alice.it> wrote:
> Hi,
>  >From startpanel, define new location with epsg codes
>  Used 4326 for WGS84
>  Returned the following message:
>  g.proj returned the following informational message: child killed: SIGABRT
>  Why?
>  Thanks
>  Marco
>  _______________________________________________
>  grass-dev mailing list
>  grass-dev at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/grass-dev
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080303/5169f698/attachment.html
