[GRASS-dev] Re: diglib and x86_64 problems
William Kyngesburye woklist at kyngchaos.com
Thu Mar 6 10:08:10 EST 2008
On Mar 5, 2008, at 9:54 AM, Henning Lorenz wrote:
> Hi William!
> No, I'm not aware of this issue - simply because grass compiled
> without any
> errors in diglib. The vector commands I use right now, mostly
> v.digit, work
> fine.
> Henning
The error is a runtime.
On Mar 6, 2008, at 1:45 AM, Henning Lorenz wrote:
> 2. For the time being I use mostly v.digit, and I did not have any
> problems with it in my or your build.
> Why can it be an OSX-x86_64 problem only and not on other systems
> with the same architecture?
The one definite example was importing a shapefile, but the place it
crashed was in the cleaning.  Did you try v.in.ogr?  Or maybe a
v.clean (break tool)?  Do you still have the 64bit build to try that?
My builds are 32bit, because of this problem, so you won't see it then.
IT is indeed a mystery why OSX 64bit has this problem.  Though I
didn't try it on PPC 64bit (no access PPC Macs with Leopard).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
