[GRASS-dev] Re: [GRASS-user] v.in.db - dylb failure
William Kyngesburye woklist at kyngchaos.com
Mon Mar 10 20:19:41 EDT 2008
Looks like that symbol isn't linking in from the mysql library.
_all_charsets appears to be a "common" symbol, which is known to cause
linking problems in OSX's default 2-level namespaces.  Mysql is
supposed to compile with the -fno-common flag on OSX, but for some
reason this _all_charsets made it in there.
I'll see what I can do...
On Mar 10, 2008, at 5:21 PM, Richard Chirgwin wrote:
> Greetings all,
> I seem to be coming up with too many posts, for which I apologise!
> This time, I have run into a v.in.db error on a colleague's machine.
> It's running William Kyngesburye's build (6.3 RC5 for Tiger) under
> OSX 10.4, and generating the following error:
> dyld: Symbol not found: _all_charsets
> Referenced from: /Applications/GRASS-6.3.app/Contents/MacOS/driver/
> db/mysql
> Expected in: /Applications/GRASS-6.3.app/Contents/MacOS/lib/
> libgrass_dbmibase.dylib
> Would this have something to do with directory links at start?
> Richard
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled
with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a
bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
